For me to run WebUI for 50,000 - 100,000 systems and 10 concurrent users I need a system with…
19 CPUS
56 GB RAM
Does this mean I need a physical system with 19 physical CPUs?
or
Does this mean I need a systems with 19 Cores?
If 19 Cores is it the same specs for a virtual system.
Who has or runs a systems with 19 physical sockets?
Who can dedicate 19 cores to a single VM?
If this is a Remote WebUI do these same specs apply?
19 CPUs
56 GB Ram
Correct me if I’m wrong, I think you’re not gonna deploy the old WebUI at 50-100k endpoints right? That WebUI hardware requirement bit you’re listing is for WebUI v9.5.3, during the ETL days.
All the assumptions there are for a collocated environment, so where WebUI, root server, and your sql server are running in the same place.
Hopefully that helps you out at least a little bit? It looks like you’re asking if the numbers change significantly when you go into the Remote WebUI scenario though right?
I think I can get back to you on that. From what I’ve seen with performance tests, the main action is going to be primarily at your DB server. That’s really where all the CPU activity is happening. So I don’t think the requirements change all that significantly. There’s not lot of ridiculous load we’re driving at the WebUI node application layer.
@sbl is your root server and DB server on the same box?
The DB and Root Server are together on one box. I am looking for system specs to run a WebUI instance on a remote system that will manage between 50k to 100K endpoints.
