WebReports problem with "Policy Compliance by Computer"
While working fine with other Security Configuration Reports, we can not get the report “Policy Compliance by Computer” printed. The other reports are printed or exported to pdf, but in the same computer, printer. custom site and console, this report is impossible to print.
We also had open a PMR with no solution ( PMR 27121,000,613 )
Can someone help ?
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
Hi Marcelo
Is not big issue dude… just install the save as pdf or Microsoft 2003 web components then you can get report as a PDF format.
else use BESWebReports:Enable PDF reports 1/2 and 2/2 fixlets available in all version of IBM Endpoint manager
and here i attached some screenshots for your reference which is taken in my environment
Regards
Vicky
