(imported topic written by nberger91)
After upgrading to the latest release of Server/Webreports, a previous report returning standard RP’s is now failing. If i (re)create the report by selecting ‘Explore Data’ --> ‘Edit Columns’ then select approx 20 Properties. I get the following error displayed in red font. If i reduce the number of columns (properties) it works. Any Ideas ?
JavaScript Error
“Failed GET request to sort=R-Computer%20Name&dir=asc&startIndex=0&results=50&c=R-Computer%20Name&c=C%2FOS%2520Type%2FYul2G0xJ9gmKgvWj9tWRvZFGvYM&c=C%2FOpen%2520Port%2520Query%2520-%2520VNC%2F4SRHuV9gUcRaZ1mxtPgnJAZpg6E&c=C%2FOpen%2520Port%2520Query%2520-%2520SNMP%2FuNiQdJwtbqdmgnSbFybhVrfo4NU&c=C%2FOpen%2520Port%2520Query%2520-%2520SMTP%2FJdlBqQkYsLU8qublEpj0tkcnTPg&c=C%2FOpen%2520Port%2520Query%2520-%2520POP3%2F30LXGST2dV4BPUmb2V%252fYg6LTFLY&c=C%2FOpen%2520Port%2520Query%2520-%2520HTTP%2FZdDZ56iSYElAU7NPz0awA2%252f2jkk&c=C%2FOpen%2520Port%2520Query%2520-%2520FTP%2FetU%252fT9XZff3JFMvEJv5mYHBLe2s&c=C%2FOpen%2520Port%2520Query%2520-%2520FINGER%2FoWeVatDxofDx2hYckpIcvk%252f%252brrY&c=C%2FNumber%2520Of%2520Relevant%2520Moderate%2520Hotfixes%2FwuXdrM0%252fSxIBGhqxxW1J%252br8aomk&c=C%2FNumber%2520Of%2520Relevant%2520Low%2520Hotfixes%2FMtCfQOPTtNQw3MMXVUfehksY2BQ&c=C%2FNumber%2520Of%2520Relevant%2520Important%2520Hotfixes%2FiYpmqn%252bYk7koSG69uBc7EugZT7k&c=C%2FNumber%2520Of%2520Relevant%2520Critical%2520Hotfixes%2FmzDTLRoVPLO7KDgoFqdPAvZ%252b2rU&c=C%2FNon-Windows%2520Computers%2FGKhl%252bY70E3jl9lpbaTO69cE3DE0&c=C%2FLast%2520Logged%2520in%2520User%2F16ERdfoBavN0yAKiApxPYwS5y5k&c=C%2FIs%2520Laptop%2FCYriq15OLjdl%252fCemWQ3BP39XacY&c=C%2FIM%2520Connected%2520Backup%2520Agent%2520Installed%2FB%252b1CJbo97yUtjikMjQbtMkuBVzg&c%2FFree%2520Space%2520on%2520System%2520Drive%2FDbC2t%252boHeBfa5Ij2MK%252b5xLmeM%252f0&c=C%2FFile%2520System%2520Type%2FND1VlwMmxTJcyarjp%252fimL3avtg8&c=C%2FEncryption%2520Status%2FwycRuV791sdyytTy43HsSwr3tz8&c=C%2FComputer%2520Type%2FwUzFAyQPtWOfCeKEuIRlQ5r0S90&c=C%2FComputer%2520Serial%2520Number%2FOBNQx9g4PeAGoZ%252fIB2E0EzDMlEA&c=C%2FComputer%2520Model%2FwUzFAyQPtWOfCeKEuIRlQ5r0S90&c=C%2FAltiris%2520Agent%2520Service%2520Status%2FYGsiufIRma%252b3laexkJY6y%252bdMzSE&c=R-Active%20Directory%20Path&c=C%2F64bit%2520OS%2520Type%2F2DBQH3DljdAVjzyc%252fvCEA3aVBoc&c=R-IP%20Address&c=R-OS&c=R-CPU&c=R-Last%20Report%20Time: Internal Server Error”
