Has anyone created or having properties for capturing details of VSS Shadow copy, related to - Which Drive, Size of them, when created, who created etc.
Or is there any way to get them using WMI.
I am not familiar with the VSS Shadow copy, however you can query an existing wmi properties with the following Bigfix inspector: “select objects of : wmi object” For example:
q: selects “* from Win32_ComputerSystem” of wmi
I saw there are some wmi objects related to VSS shadow copy such as “Win32_ShadowCopy” you can give it a test with the bigfix inspector using the qna on your VSS shadowed environment:
q: selects “* from win32_shadowcopy” of wmi
