We are trying to change VMs using VMWare Modify Virtual Machine fixlet but it only providing option to use one Host & one VM in one action, and we have to modify aprox 300+ VMs.
Is there any option we can pass multiple host & their VMs into it & change them in phases like 50 in one go.
Have you considered leveraging the BigFix REST API to action the fixlet? Create a script to loop through your list of servers that need to be modified and each loop iteration calls the REST API with the current server name as the input. While this will create many actions, it will provide you with the desired end results of automating using the provided “VMware Modify Virtual Machine” fixlet without modification.
