Using powershell in fixlets with embedded bigfix code
written by SystemAdmin)
I’m attempting to search and replace the word HOSTNAME and replace it with {hostname as uppercase} in a template file downloaded to each endpoint using a powershell script. In the example below, this fails on the line containing {hostname as uppercase}. Looking for suggestions on other ways to accomplish this or do I just have syntax wrong?
createfile until __EOF
Get-Content “D:\Apps\Cybermation\ESP System Agent R7\agentparm.new”) |
Foreach-Object {$_ -replace “HOSTNAME”, “{hostname as uppercase}”} |
Set-Content “D:\Apps\Cybermation\ESP System Agent R7\agentparm.txt”
__EOF
move __createfile “D:\Apps\Cybermation\ESP System Agent R7\updatehost.ps1”
rundetached “C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe &D:\Apps\Cybermation\ESP System Agent R7\updatehost.ps1”
I beleive the problem is that bigfix is trying to interpet the outer { } around the command as they turn pink in the editor
That’s correct! If you don’t want the curly braces treated as a special character (e.g. Relevance substitution) you will ha to escape it. You can do that by doubling up on only the first one. For instance:
Createfile until …
Will evaluate the relevance
Createfile until …
{{hostname as uppercase}
Will not evaluate the relevance.
I DO want the {hostname as uppercase} to evaluate, but not the {$_ and } | at the end
It’s failing because everything inside of the outer set of {} turns pink in the editor and failes when it’s run
Ahh… Here are a couple other ways to escape it based on your use case:
https://www.ibm.com/developerworks/forums/thread.jspa?messageID=14750659&#14750659
Almost, but that’s opposite of what I need. I need the internal {} to evaluate and the outer to not…
Does it not work if you use %7B and %7D instead of {} for the ones you don’t want interpreted?
So something like:
Foreach-Object %7B$_ -replace “HOSTNAME”, “{hostname as uppercase}”%7D |
Another, maybe not so elegant, way to do this might be to build the whole line in relevance inside the curly braces:
q: {“Foreach-Object %7B$_ -replace %22HOSTNAME%22, %22” & (hostname as uppercase) & “%22%7D |”}
A: Foreach-Object {$_ -replace “HOSTNAME”, “WIN-SMD2P7N3F49”} |
T: 2.198 ms
I: singular string
That worked to create the updatehost.ps1,
(Get-Content “D:\Apps\Cybermation\ESP System Agent R7\agentparm.new”) |
Foreach-Object {$_ -replace “HOSTNAME”, “WSPRD304”} |
But the command to run powershell against the file says it completes, but never produces results.
I don’t think it executed the powershell command.
__EOF
copy __createfile “D:\Apps\Cybermation\ESP System Agent R7\updatehost.ps1”
waithidden cmd.exe /C “C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe ‘D:\Apps\Cybermation\ESP System Agent R7\updatehost.ps1’”
Forgot about that part… I just went through this a a couple weeks ago. It is an issue with 64/32 bit systems. You have to set powershell to unrestricted in both. And this is where you run into problems on 64bit machines. Here is a little more info for your reading pleasure:
http://www.paessler.com/knowledgebase/en/topic/7773-powershell-script-works-from-powershell-prompt-but-not-from-prtg
You have to enable unrestricted in both 32 bit (powershell.exe) and 64 bit (C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell.exe)
Here is an example I set up recently.
//Set to Unrestricted
//32 bit
if {name of operating system as lowercase contains “win” and architecture of operating system = “x86”}
wait cmd.exe /C powershell.exe -noninteractive -Command Set-Execution Policy “Unristricted”
//64bit
else
wait cmd.exe /C C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell.exe -noninteractive -Command Set-Execution Policy “Unristricted”
endif
//delete files if pre existing
delete “c:\test.txt”
delete “c:\test.ps1”
Get-WmiObject -Class Win32_OperatingSystem -Namespace root/cimv2 -ComputerName . | Format-Table -Property TotalVirtualMemorySize,TotalVisibleMemorySize,FreePhysicalMemory,FreeVirtualMemory,FreeSpaceInPagingFiles
__EOF
move __createfile c:\test.ps1
wait cmd.exe /C powershell.exe c:\test.ps1 >> c:\test.txt
else
wait cmd.exe /C C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell.exe c:\test.ps1 >> c:\test.txt
endif
Sounds interesting, but even with running
powershell.exe D:\Apps\tmp\updatehost.ps1
it fails to execute from within bigfix. Command line it works just fine.
I tried those commands you suggest, but get errors setting them
The term ‘Set-Execution’ is not recognized as the name of a cmdlet, fuction, script…
This sounds exactly like the issue I had. I am no powershell expert but I muddled my way through once I realized there were 2 different powershells and that the ExecutionPolicy had to be set to unrestricted.
More details:
Try running the following commands at the command line:
c:>%SystemRoot%\syswow64\WindowsPowerShell\v1.0\powershell.exe
PS c:>Get-ExecutionPolicy
C:>%SystemRoot%\system32\WindowsPowerShell\v1.0\powershell.exe
I originally only had the 32 bit version set to unrestricted. That was why I added the piece that was capturing the “c:\test.txt” so I could see what the output from running the ps1 was.
Jeff,
Sorry for fumbling through this… It is all coming back slowly.
Of course the first part of the script as I have it above won’t work. You can’t script powershell until you change it from the default “restricted”. And I was trying to script it to change it… The Execution policy can simply be changed in the registry. I just tested this one against a x64 server. See if this helps:
//32 bit
regset "
http://HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell
" “ExecutionPolicy”=“Unrestricted”
//64bit
else
regset "
http://HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell
endif
__EOF
else
endif
You are correct about the restricted mode. I’ve built a PowerShell template fixlet last year and you might find it helpful to compare.
http://bigfix.me/cdb/search/powershell
Wowzers. Any reason it can’t or shouldn’t be done with PowerShell’s -ExecutionPolicy parameter? That seems like an easier way to change the policy temporarily…
waithidden powershell.exe -ExecutionPolicy Unrestricted YourPSFile.psl
