Using Big Fix to create a certain folder on certain servers
(imported topic written by garbroo91)
I am trying to use Big Fix to create a folder C:\logs on some of my servers. Has anyone ever created a task to create folders?
Any help would be appreciated.
thanks,
Hi garbroo,
This should be a simple task:
Relevance:
not exists folder “C:\logs”
Action:
dos mkdir “C:\logs”
(imported comment written by garbroo91)
Ben, thanks I will give it a try this morning.
Ben, when I run the following in the relevance debugger
not exists folder “C:\logs” dos mkdir “C:\Logs”
I get the following Error: The operator “dos mkdir” is not defined.
Any ideas? I will keep playing with it.
Ben,
I don’t know why the expression did not work in the relevance debugger?? I just created the task
relevance: not exists folder “C:\logs”
action: dos mkdir “C:\Logs”
and it worked on my test server. I still don’t understand why it bombs in the relavance debugger but life is too short to worry about that.
thanks for you help,
Gary
Hi Gray,
dos mkdir “C:\Logs” // this is Action script
not exists folder “C:\Logs” // this is Relevance
Action script and relevance are 2 different languages. You can’t use action script in relevance, although you can embed relevance in action script by enclosing it in curly braces {}.
The distinction is important. Relevance is used for querying things, but by design it can’t make any changes. The relevance debugger doesn’t know anything about action script and thus it bombs out when you try to evaluate an action script statement.
We do have a new tool that understands both! You can use it to test your relevance and to test your actions. Check it out: http://forum.bigfix.com/viewtopic.php?id=1606
Jesse
