Use Tivoli Remote Control site in "Create in site" is possible?
i’ve customizated a Remote Control fixlet, so i would to see it uder the Remote Control menu (implementation)…
Is it Possible ?
When I create a new fixlet/task i can create only in Master Action Site, is it normal ?
Thanks in advice.
Hi prime,
If you are making a custom Fixlet or a custom copy, you can put it either in your actionsite or in a Custom Site. You can’t put custom Fixlets in an external site.
