Use of BES and Wiki for Win DNS configuration management using VBS
(imported topic written by ononcg91)
Overview of Win DNS configuration management using VBScript and Wiki as revision control.
Win DNS update is performed by VBScript “update-dns.vbs”:
Set WshArgs = WScript.Arguments
bDebug = False
aNewDNSServersAMER = Array (“10.160.29.90”, “10.168.29.87”)
aNewDNSServersAPAC = Array (“10.128.2.87”, “10.160.29.90”)
aNewDNSServersEMEA = Array (“10.0.0.84”, “10.160.29.90”)
If WshArgs.Count = 0 Then
WScript.Echo “Must specify region.”
WScript.Quit (1)
Else
sRegion = WshArgs (0)
If StrComp (sRegion, “AMER”, vbTextCompare) = 0 Then
aNewDNSServers = aNewDNSServersAMER
ElseIf StrComp (sRegion, “EMEA”, vbTextCompare) = 0 Then
aNewDNSServers = aNewDNSServersEMEA
ElseIf StrComp (sRegion, “APAC”, vbTextCompare) = 0 Then
aNewDNSServers = aNewDNSServersAPAC
Else
WScript.Echo “Invalid region specified.”
WScript.Quit (1)
End If
aComputers = Array (“.”)
End If
If WshArgs.Count > 1 Then
sListFile = WshArgs (1)
beaDebugPrint "File: " & sListFile
aComputers = FileToArray (sListFile)
End If
nErrorLevel = 0
For Each sComputer In aComputers
nSuccess = beaNetworkUpdateDNS (sComputer, aNewDNSServers)
If nSuccess = 0 Then
beaDebugPrint "Successfully updated DNS on " & sComputer
Else
beaDebugPrint "Failed updating DNS on " & sComputer
nErrorLevel = 1
End If
Next
WScript.Quit (nErrorLevel)
Function beaNetworkUpdateDNS (sComputer, aDNSServers)
sWMINicSearch = “SELECT * FROM Win32_NetworkAdapterConfiguration WHERE IPEnabled = True AND DHCPEnabled = False”
nReturn = 0
On Error Resume Next
beaDebugPrint "Computer: " & sComputer
Set oWMIService = GetObject (“winmgmts:{impersonationLevel=impersonate}!\” & sComputer & “\root\cimv2”)
If Err = 0 Then
Set colNicConfigs = oWMIService.ExecQuery (sWMINicSearch)
For Each oNicConfig In colNicConfigs
If Not IsNull (oNicConfig.IPAddress) Then
beaDebugPrint "Network Adapter " & oNicConfig.Index & " - " & oNicConfig.Caption
beaDebugPrint " IPEnabled: " & oNicConfig.IPEnabled
beaDebugPrint " DHCPEnabled: " & oNicConfig.DHCPEnabled
bSkipNic = False
For i = LBound (oNicConfig.IPAddress) To UBound (oNicConfig.IPAddress)
beaDebugPrint " IPAddress: " & oNicConfig.IPAddress(i)
nCompare = StrComp (oNicConfig.IPAddress(i), “192.168.234.235”, vbTextCompare)
If nCompare = 0 Then
bSkipNic = True
End If
Next
If bSkipNic = False Then
beaDebugPrint vbTab & “DNS Server Search Order - Before:”
If Not IsNull (oNicConfig.DNSServerSearchOrder) Then
For Each sDNSServer In oNicConfig.DNSServerSearchOrder
beaDebugPrint vbTab & sDNSServer
Next
End If
nSetDNSServers = oNicConfig.SetDNSServerSearchOrder (aDNSServers)
If nSetDNSServers = 0 Then
beaDebugPrint vbTab & “Replaced DNS server search order list.”
nReturn = 0
Else
beaDebugPrint vbTab & “Unable to replace DNS server search order list.”
nReturn = 1
End If
Else
beaDebugPrint vbTab & “Skipping Nic.”
End If
End If
Next
Else
beaDebugPrint “Unable to connect to computer.”
nReturn = 1
End If
beaNetworkUpdateDNS = nReturn
End Function
Sub beaDebugPrint (sOutput)
If bDebug = False Then
Exit Sub
End If
WScript.Echo Now & " " & sOutput
End Sub
Function FileToArray (ByVal sFilename)
Set oFSO = CreateObject (“Scripting.FileSystemObject”)
Const ForReading = 1
FileToArray = Split (“”)
If oFSO.FileExists (sFilename) Then
beaDebugPrint "File exists: " & sFilename
Set oTS = oFSO.OpenTextFile (sFilename, ForReading)
If Err = 0 Then
sContents = oTS.ReadAll
oTS.Close
FileToArray = Split (sContents, vbNewLine)
Else
WScript.Echo "Error opening: " & Err.Number
WScript.Quit (1)
End If
Else
WScript.Echo "File does not exist: " & sFilename
WScript.Quit (1)
End If
End Function
“update-dns.vbs” requires DNS region provided as argument e.g. “AMER”, “APAC” or “EMEA”.
This can be run independently of BES deployment either standalone on a system or run via
WMI on list of systems contained in text file provided as argument.
VBScript is uploaded to Wiki as “update-dns.vbs.txt”.
Each DNS region has its own BigFix task but all use the same VBScript.
Excerpts of “Win AMER DNS update” BigTask task.
Relevance:
name of operating system as lowercase starts with “win” AND not (exists addresses whose (it as string = “10.160.29.90”) of dns servers of network and exists addresses whose (it as string = “10.168.29.87”) of dns servers of network)
Action:
download as update-dns.vbs.txt http://mywiki/download/attachments/1212747/update-dns.vbs.txt?version=1
continue if {(size of it = 4581 and sha1 of it = “35f8ad17f5eecc4de922aec9184e4d37269289fb”) of file “update-dns.vbs.txt” of folder “__Download”}
delete __Download\update-dns.vbs
move __Download\update-dns.vbs.txt __Download\update-dns.vbs
run wscript.exe __Download\update-dns.vbs AMER
The action script size and sha1 are obtained by using the the BigFix SHA1 utility:
sha1 -r update-dns.vbs.txt
Confluence is the Wiki used for this implementation. The use of query string to specify version is a very nice
feature.
