Urgent: SUA 2.0 Issue with IMPORT
(imported topic written by Corda)
Hello, I installed the application Web SUA V 2.0 on a different server and its remote database (tem_analytics) on the TEM Server. When I run the task, the import hangs at 1% and does not go more forward. The problem does not occur when the database (tem_analytics) is local.
In attachment the logs. Can you help me?
2013-07-31 14:51:09 Commons Daemon procrun stderr initialized
C:/Program Files/BigFix Enterprise/TEMA/work/tema/webapp/WEB-INF/config/initializers/uri.rb:12 warning: already initialized constant DOMLABEL
C:/Program Files/BigFix Enterprise/TEMA/work/tema/webapp/WEB-INF/config/initializers/uri.rb:13 warning: already initialized constant HOSTNAME
C:/Program Files/BigFix Enterprise/TEMA/work/tema/webapp/WEB-INF/domains/sam/db/migrate/001_initialize.rb:672 warning: Object#id will be deprecated; use Object#object_id
./lib/etl.rb:13 warning: already initialized constant HOOKS
Marco
(imported comment written by MichalPaluch)
Hello, please contact support. Thanks!
