Updated versions of ComputerRemover and AuditTrailCleaner?
(imported topic written by rmnetops91)
Are there updated versions that correspond to v8.0 for the following?
  • Audit Trail Cleaner
  • Computer Remover
  • Download Cacher
Not sure about the AuditTrailCleaner but you can find the BESComputerRemover here
http://support.bigfix.com/bes/install/downloadutility.html#bescomputerremove
FWIW, We had the same issue with the Computer Remover tool - http://forum.bigfix.com/viewtopic.php?id=5539 - The new version did the trick. I wish fixlets were published or some type of notice was included in the release notes for the tools.
(imported comment written by rmnetops91)
Does anyone know if there is an updated BESClientHelper fixlet? I didn’t see one and am wondering if there was any change to the .exe for this service that may need to be updated.
I answered my own question. BESClientHelper.exe version is still the same. v2.4.0.52
I get the following error after running besaudittraincleaner.exe (v3.0.10.3) on Bigfix v8.0.584.0.
Has this not been updated to run on version 8?
  • Custom Content History
Number of rows in LOCAL_OBJECT_DEFS table: 491
Total Number of Rows for Custom Content History: 491
  • Action History
Number of rows in ACTION_DEFS table: 440
Total Number of Rows for Action History: 440
  • Deleted Custom Content
Number of rows in LOCAL_OBJECT_DEFS table: 559
Number of rows in VERSIONS table: 223
Number of rows in FIXLET_COMMENTS table: 4
DBD::ODBC::st execute failed:
Microsoft
http://SQL Server Native Client 10.0
SQL Server
The SELECT permission was denied on the object ‘FIXLETRESULTS’, database ‘BFEnterprise’, schema ‘dbo’. (SQL-42000)(DBD: st_execute/SQLExecute err=-1) at /<E:\Data\Bigfix_tools_v8\BESAuditTrailCleaner.exe>BESTools/Databases.pm line 363, line 165.
DBD::ODBC::st fetchrow_array failed: (DBD: no select statement currently executing err=-1) at /<E:\Data\Bigfix_tools_v8\BESAuditTrailCleaner.exe>BESTools/Databases.pm line 365, line 165.
Use of uninitialized value in numeric eq (==) at /<E:\Data\Bigfix_tools_v8\BESAuditTrailCleaner.exe>BESTools/Databases.pm line 386, line 165.
ERROR: SQL Select call did not return results (2).
