Has anyone else noticed this since upgrading to 8.1 …
I have several custom tasks that have an action to run a shell script, in the most these are dynamically created shell scripts. For example I have an action that creates a list of GENxxxxxx SCM scripts that I want to evaluate. The action then creates a dynamic shell script to execute the runme.sh Bigfix script :-
appendfile #!/bin/sh appendfile cd
{((pathname of parent folder of parent folder of folder (pathname of client folder of current site)) &
"/SCM")
} appendfile ./runme.sh -F ba_baseline_phase1_scm_list
To execute my dynamic shell script I use:- wait /bin/sh -c “./run_SCM_phase1.sh” in the action (it also happens if I omit the ‘-c’ parameter from the command).
However, the agent doesn’t always recognise that the script has completed and move on to the next task/fixlet in it’s ‘list’. After a while, the server appears in the console as ‘Not Reported’ and I have to log on to the server, stop and start the agent and then the agent carries on OK. Not always but occasionally I see ‘Command failed (Action aborted before completion) wait /bin/sh -c “./run_SCM_phase1.sh” (fixlet 12941)’ in the log but there is definately no ‘run_SCM_phase1.sh’ or ‘runme.sh’ processes running.
There doesn’t seem to be any pattern (except that it is always a shell script that causes it to hang) and quite often it will execute the actions correctly.
