Is there a reason why 2 relays might generate network traffic between them if none of them is parent for the other (they have the same parent relay which is the main server?
Thank you!
Thank you!
How are you monitoring this traffic?
Is it trough the port 52311?
What type of traffic? ICMP? TCP? UDP? Port?
How much and how frequent is the traffic?
Sorry, I misunderstood the situation as the issue was formulated wrong.
We actually have a few devices that had a peak traffic usage on these 2 devices and this caused issues, users experiencing slow response and applications not responding.
The weird part is that we didn’t have any large deployments on any of these devices when the peak got signalled.
Any ideas what can we investigate on this?
On relays’ logs we had entries as seen below:
Mon, 22 Aug 2016 10:18:23 +0100 - PeriodicTasks (3184) - GetExpectedVersionOfParent Error: HTTP Error 56: Failure when receiving data from the peer: Recv failure: Connection was reset
Mon, 22 Aug 2016 09:33:55 +0100 - /cgi-bin/bfenterprise/clientregister.exe (5884) - GetExpectedVersionOfParent Error: HTTP Error 56: Failure when receiving data from the peer: Recv failure: Connection was reset
PeriodicTasks (3156) - Error running task UpdateAndSendRelayStatus: HTTP Error 28: Timeout was reached: Connection timed out after 10000 milliseconds
Fri, 19 Aug 2016 14:26:23 +0100 - /cgi-bin/bfenterprise/clientregister.exe (5696) - Uncaught exception in plugin ClientRegister with client 10.73.4.148: HTTP Error 28: Timeout was reached: Connection timed out after 10000 milliseconds
Mon, 22 Aug 2016 12:59:41 +0100 - /cgi-bin/bfenterprise/PostResults.exe (5052) - Uncaught exception in plugin PostResults with client : Socket Error: Windows Error 0x2746: An existing connection was forcibly closed by the remote host.
Thank you!
Which port do you identify to be used during that overload?
The logs shows that also bigfix had problems to communicate to parent device
Are the relays Windows or Linux? Is the parent Windows or Linux?
All Windows. Port 52311
