It always made sense to me that relays selecting other relays could work exactly the same way as clients selecting relays, it just could be a problem if it can’t find any relays in the affiliation group and then failed over to a random one, because then you could have relays in a never ending circle.
If I recall correctly, a Relay will never use Automatic Relay Selection. Tim was correct in his earlier post that you need to configure these settings:
__RelayServer1
__RelayServer2
_BESClient_RelaySelect_TertiaryRelayList
_BESClient_RelaySelect_FailoverRelay or _BESClient_RelaySelect_FailoverRelayList
…except that these need to be configured on every relay.
__RelayServer1 and __RelayServer2
can be configured by right-clicking on Relay’s computer account in the console and selecting “Properties” or “Edit Settings”. But I don’t think that dialog has places to put in the TertiaryRelayList nor the FailoverRelay / FailoverRelayList settings, you’ll need to use the fixlets from the BES Support site or your own Task to configure those.
I’m not sure whether RelaySelect_Automatic needs to be set to 0; I think that setting is ignored on Relays anyway.
BigFix Relays themselves do not use automatic relay selection when deciding which parent BigFix Relay or BigFix Server to use so the BigFix Relay affiliation process does not apply when BigFix Relays pick their parent. BigFix Relays will use the standard manual relay selection and failover behavior.
But that’s not what I’ve just experienced in my lab. It may have been because the client of the sub-level relay was pointed at the top level relay BEFORE installing the relay on the sub-level relay client. Since I did that, the relay now uses the top level relay as the parent of the sub-level relay which is what I want to happen in our production environment. There really isn’t an issue with ping in our environment especially since the name of the relay is the FQDN.
The problem I have is I assigned the two top level relays manually before but the parent relay didn’t change no matter how many times I restarted the client or ran the manual selection. I couldn’t get clients (even clients sitting on the same subnet) to take the relay as a parent using manual selection
Is there a host-based firewall, perhaps blocking the ICMP on the relay? I’d suggest running a network capture from the child relay during a relay selection.
In any case, in my “bag of dirty tricks”, I’ve had situations when cloning machines with a preinstalled copy of the BES client, where the target machine cannot reach any of the relays that existed at the time the image was created; so it cannot learn about the newer relays installed at the client site. In that situation, I’ve updated the HOSTS file on the client so that it thinks the root server has the IP address of the nearest relay. You might try modifying the client hosts file (or even your DNS infrastructure) to assign the root server name(s) to the top-level relay IP addresses.
I think I recall @jgstew posting something similar here…was it called a shadow root? Only your Console machines and top-level relays need to correctly resolve the root servers, so those could have “correct” HOSTS file entries, to override the “false” DNS results that are used by the rest of the infrastructure.
Fake Root is what it has been called, but I suppose there is no official term.
You can do this also if you have control over the DNS of the machines at the remote location. You can just set the DNS they use to resolve the root server as a local relay. You probably could even use DNS load balancing to have the DNS resolve the hostname of the local relays randomly instead of always returning the same IP, though it would need to return the same IP for the same connecting client for things to really work well.
The “Fake Root” concept goes even further and has the root DNS name ALWAYS resolve to a single top level relay instead of the root server. This allows you to more easily restrict access to the root server. It also allows you to keep load off of the root server and put as much load as possible on this single top level relay that can be swapped out much more easily than the root server. You can put a lot of storage on the cache of this top level relay and set it to do internet downloads so that they are not done by the root and reduce the storage needs of the root server. You can also have this top level relay be the one responsible for decrypting reports. You could set it to hold onto more reports for longer so that it can send them up to the root in larger batches to further reduce load on the root server.
Looks like its time for me to add some background info.
Relays do not perform any relay selection. The accompanying client performs this work for it. The client will obviously use the relay it is installed with but does find the parent that the relay talks to and instructs the relay to talk to that parent. By default, auto relay selection is NOT enabled when a client has a relay attached. There is another setting to do that but it isn’t something we recommend so I’m not going to mention the setting.
If you look in the logs of the recent clients (like 9.2) you will see the relay selection of the client show that it is using the localhost but has chosen its parent.
So, there are still cases where the client of an installed relay will fail over to root but it has to go through all these first, and as the comment of one of the settings states, Manual selection goes in this order, primary/secondary/tertiary list/failover/root
Type: String
Version: 7.0
Platform: All
Default:
Requires Client Restart: NO
Description: semi-colon delimited list of relays to try.
Type: String
Version: 5.1
Platform: All
Default:
Description: failover relay used if configured and nobody is responding to pings. Like __RelayServer1, it should be of the form http://server:52311/cgi-bin/download
Type: String
Version: 9.0
Platform: All
Default:
Description: A semicolon delimited list of failover relay names used if configured and nobody is responding to pings. If present and not empty, it replaces _BESClient_RelaySelect_FailoverRelay
You obviously can still end up with cases where a client will chose the root as its parent, and a Fake Root (or impersonating root or however you want to call it) as @jgstew mentions is the only way to prevent that. A top level relay masquerading to everyone but consoles and that relay as the server is the only real way of preventing clients from getting to the root either by failing over or by initial install.
I’ve been using relay auto selection along with appropriate seek and advertisement list for over 8 years and have never had issues. I set the following settings on the relays.
_BESClient_Relay_EnableAutomaticSelection
This is the setting @AlanM is keeping secret (sorry). This tells the client with a relay to allow it to use automatic relay selection
_BESRelay_Register_Affiliation_AdvertisementList
This is what the relay advertises to clients or other relays
_BESClient_Register_Affiliation_SeekList
This is what the seek list the client and relays will use. I also set this setting on all the clients to specify their seeklist.
Not trying to keep anything secret, but be aware when using this that in some circumstances you will end up with circular relay selections. The client does its best to detect this but if you have relay C pointing to relay B pointing to relay A pointing to relay C because they are all equally good relays… you can see the problem.
Again with any setting we have, they override default behaviour for certain circumstances and should be considered before using them
Hello Alan,
For the tertiary relay list trying, Is the connection tried as the order which is written ?
Or, is it connected randomly in relay of List which is written within tertiary list ?
@jmaple , are you just trying to set permanent parent relays to your subrelays? I’m not sure why you would want relays to be set to Automatic, this would cause adverse effects in my environment and having these set to manual is what is giving me control to the flow of the endpoint communication. We are using relay affiliation with the Seeklist and Advertisement settings as mentioned above, targeted for “All Computers” and we have our Advertisement lists based on which clients you want them to be able to communicate with directly. For the parent relay selection, we just edit the computer setting of the Relay, then set a PRI and BACK and call it a day. What is the need for auto relay selection for a relay in your environment? Also, as @jgstew was stating, why so may relays in such a small environment? I think the max is 1k clients per relay.
@heagsta: As @AlanM has stated, relays do not perform the automated selection like normal clients.
Our advertisement list is working like a charm so I’m not concerned with that so much. At this point my issue was resolved by forcing my relays to be manually set to their respective top-level relays. I was not part of the initial deployment of our infrastructure so we have quite a few relays where it’s not necessary and while I could get rid of half of them, everything is working and I don’t see a reason to rock the boat. I just wanted to be sure that when I enabled encryption, my top-level relays were the decryption relays and my main server didn’t have to decrypt reports.
@jmaple, I understand that relays do not perform automatic relay selection, but throughout the thread, I thought you were looking for a more complex solution for a problem I wasn’t understanding fully, instead of just manually assigning the parent relays. Either way, at least it is working as advertised now. Good info on the decryption, I have not worked with that as of yet.
There are times when it makes sense to add a relay for reasons other than the number of clients connecting, like to help with UDP notifications and WAN bandwidth.
