Top 30 Vulnerable systems
Hello Everyone,
I’ve got a question regarding extracting systems out of Web Reports that are in need if the most critical fixlets. I’ve tried many approaches but haven’t been able to get the output to present in the way I would like. It seems like it would be simple and perhaps I’m missing something, but all the output really needs to display for example, is the top 30 systems in need of the most critical fixlets. I’ve tried using filter configurations but haven’t had any luck.
Does anyone have any advice on this or is there a custom report out there that might do something similar?
Thanks in advance,
John
Have you seen the
Fixlet Compliance by Computer Group
report?
It will show you the top 15 most vulnerable computers.
If you have a lot of computers, note that it will take a while to generate the report.
See the attached example.
Lee Wei
