TEM <not reported>
(imported topic written by jdefilip)
Hi, I have just deployed the TEM Client and created an action to Change’_RelaySelect_Automatic’ Setting. Only 15% of the computers have completed. The remaining computer are in the status. Any assistance would be greatly appreciated.
Thanks!
‘’ means that the client has yet to run the action, usually because they didn’t receive the UDP “ping” on port 52311 from their TEM Relay. Every time you take an action in the console or update anything, the TEM relays ping their clients on UDP:523211 telling them to check in and see that there is something new to do. If the clients don’t receive the ping, then they basically wait until their default checkin time, which is by default, every 24hrs i think.
http://www-01.ibm.com/support/docview.wss?uid=swg21505835
(imported comment written by jdefilip)
That is correct UDP requests were not being received. Thanks you!!!
