TASK, Action Script - parameter and if problem
Hello
i try to deploy a software package with different parameters based on the manufacturer.
The line with the if clause is always failed.
Can anyone give me a hint please ?
Martin Forster
download http://bes.itiso.net:52311/Uploads/41ac12e046119c2d27945c75793818480421a22b/big38.tmp
continue if { (size of it = 141791733 and sha1 of it = “41ac12e046119c2d27945c75793818480421a22b”) of file “big38.tmp” of folder “__Download”}
extract big38.tmp
parameter “MF” = {if (exists wmi) then (string value of select “Manufacturer from Win32_ComputerSystem” of wmi as lowercase) else (“n/a”)}
dos net localgroup Administrators itiso_atdoao_appmgr /add
if { parameter “MF” } = “hp” or {parameter “MF” } = “hewlett packard” or { parameter “MF”} = "hewlett packard " or { parameter “MF” } = “compaq”
wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall-hp.ini"
elseif { parameter “MF” } = “fsc” or{ parameter “MF” } = “fujitsu siemens” or { parameter “MF” } = “siemens ag” or { parameter “MF” } = “sni ag” or { parameter “MF” } = “fujitsu siemens computers”
wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall-FSC.ini"
else
wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall.ini"
endif
OR
extract big38.tmp
if { parameter “MF” = “hp” or parameter “MF” = “hewlett packard” or parameter “MF” = "hewlett packard " or parameter “MF” = “compaq” }
elseif { parameter “MF” = “fsc” or parameter “MF” = “fujitsu siemens” or parameter “MF” = “siemens ag” or parameter “MF” = “sni ag” or parameter “MF” = “fujitsu siemens computers” }
else
endif
Martin,
You need to put your comparison operator inside the curly braces so they are evaluated as relevance.
Instead of this:
Do this:
if { parameter “MF” = “hp” OR parameter “MF” = “hewlett packard” OR parameter “MF” = "hewlett packard " OR parameter “MF” = “compaq” }
Alternately:
if { (it = “hp” OR it = “hewlett packard” OR it = “compaq” ) of parameter “MF” }
-Jesse
HI jessewk
i think i have done this in my 2nd try, or have i misunderstood something ?
Must the OR be in capital ?
Martin
No, the capitalization of the OR does not matter, but the capitalization of the result returned by your wmi query does. You might try this:
if { (it = “hp” OR it = “hewlett packard” OR it = “compaq” ) of (parameter “MF” as lowercase) }
Something must be still wrong ?
i already have a as lowercase at the creation statement of the property.
The action has been run 1 time, and will not be run again.
The action failed.
Completed: download http://bes.itiso.net:52311/Uploads/41ac12e046119c2d27945c75793818480421a22b/big38.tmp
Completed: continue if { (size of it = 141791733 and sha1 of it = “41ac12e046119c2d27945c75793818480421a22b”) of file “big38.tmp” of folder “__Download”}
Completed: extract big38.tmp
Completed: parameter “MF” = {if (exists wmi) then (string value of select “Manufacturer from Win32_ComputerSystem” of wmi as lowercase) else (“n/a”)}
Completed: dos net localgroup Administrators itiso_atdoao_appmgr /add
Failed: if { (it = “hp” OR it = “hewlett packard” OR it = "hewlett packard " OR it = “compaq”) of parameter “MF” }
elseif { (it = “fsc” OR it = “fujitsu siemens” OR it = “siemens ag” OR it = “sni ag” OR it = “fujitsu siemens computers” ) of parameter "MF}
else
endif
im now completely lost when i replace the wmi query with a action parameter query everything works fine.
Please note that i typed in “hp” in the message box. I have also tested the wmi query- it works.
Completed: action parameter query “MF” with description “Please enter Hardware type Samples: fsc hp noname”
Completed: // parameter “MF” = {if (exists wmi) then (string value of select “Manufacturer from Win32_ComputerSystem” of wmi as lowercase) else (“n/a”)}
Completed: if { (it = “hp” OR it = “hewlett packard” OR it = "hewlett packard " OR it = “compaq”) of parameter “MF” }
Completed: wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall-hp.ini"
Completed: elseif { (it = “fsc” OR it = “fujitsu siemens” OR it = “siemens ag” OR it = “sni ag” OR it = “fujitsu siemens computers” ) of parameter "MF}
Completed: wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall-FSC.ini"
Completed: else
Completed: wait __Download\setup.exe SILENTINI"__Download\AppManagerInstall.ini"
Completed: endif
Martin,
I should have read your action script more closely to realize that you were already casting to lowercase. Sorry.
I think you might have to place quotes around the relevance used to set the parameter. For example:
parameter “MF” = “{if (exists wmi) then (string value of select “Manufacturer from Win32_ComputerSystem” of wmi as lowercase) else (“n/a”)}”
Give that a try and let us know if it does/doesn’t work.
That was finally the solution
Thanks jessewk those tiney litte " maked the job
Thread can be closed now.
