Switching of Actionsite between Servers
(imported topic written by Anthony91)
I have a question here, hope someone would be able to assist me with it.
The task “switching of actionsite of BES clients” will set the root server as the relay instead of other relays
In the task, I notice all the relay setting are reset to blank and isnt it that the client will automatically connect to the relays instead to the root server after the services has restarted by the task actionscript?
By the way the relay selection method was set to automatic all the while.
Hi Anthony,
The task to switch mastheads will clear the relay settings because the client won’t be able to use the same relay after the masthead is switched… So the agent will contact the main server, get a list of the new relays, and then use the appropriate relay in the new deployment.
(imported comment written by Anthony91)
Hi Ben,
I understand the switching of actionsite will reset the relays, just found out that it will take some time for the client to select the relays like you had mentioned.
Thanks for your response.
