Hi Team,
I’m running into a bit of a challenge with an application install.
I’m trying to install SAP LiveOffice
reference:
https://www.itninja.com/software/sap/businessobjects-live-office/4-3921
prefetch 3dde14a20bd25e915730f2cd5a19a1fe2accf066 sha1:3dde14a20bd25e915730f2cd5a19a1fe2accf066 size:246937915 http://TheCookieFactory.com/51050613_5.ZIP.tmp sha256:b3cac430a68f9332e44a883c637a63d595a884718a99e476bd7c879ddeffe1ec
extract 3dde14a20bd25e915730f2cd5a19a1fe2accf066
// - This unzip is a compiled verion of unzip v5.52
prefetch unzip.exe sha1:e1652b058195db3f5f754b7ab430652ae04a50b8 size:167936 http://software.bigfix.com/download/redist/unzip-5.52.exe
// Add unzip.exe to the client utility cache
if {exists file (pathname of client folder of current site & "\__Download\unzip.exe")}
utility __Download\unzip.exe
endif
//Unprovisioning clients
waithidden __Download\unzip.exe -o "{pathname of client folder of current site}\__Download\51050613_5.ZIP " -d "{pathname of client folder of current site}\__Download"
dos taskkill /F /IM excel.exe
dos taskkill /F /IM winword.exe
dos taskkill /F /IM powerpnt.exe
dos taskkill /F /IM outlook.exe
waithidden __Download\SBOP_BI_PLAT_4.2_SP2_CLNT_WIN_\DATA_UNITS\LiveOffice\setup.exe -r response.ini
So my question really is, when I use the switches like -r and the path of -r do they need to go in quotes.?
The funny thing is that it shows completed with exit code 0 and the application is not installing.
so first I checked if it was uncompromising (first time using it btw) so yes, its there
then I check the path in the client:
C:\Program Files (x86)\BigFix Enterprise\BES Client\__BESData\CustomSite_Desktop_-2d_SuperUser\__Download\SBOP_BI_PLAT_4.2_SP2_CLNT_WIN_\DATA_UNITS\LiveOffice\setup.exe
thats the location so, it seems right.
I dont know what else to do
Any help greatly appreciated.
