Starting failed besclient ESX 4.0
Hi All,
Anyone encountered the same problem with ESX 4.0? installation is successful but can start the BESClient.
Thanks,
Brai
Don’t know if you got your answer correctly but did you copy your masthead into /etc/opt/BESClient as actionsite.afxm ?
Also please make sure you install the correct agent (its the Red Hat 5 x86_64 64 bit agent for ESX 4)
