I am trying to configure my web report to use SSL.
When I set _WebReports_HTTPServer_UseSSLFlag = 1, and restart it.
The BESReport is up, but It is no longer to listen to port 52312.
I checked the log, and found this error.
HTTPServer error: No such file or directory; system lib; system lib (class OpenSSLError)
When I change back to 0. It is able to use "https://server-name:52312’ . And it ask for cert exception as I am using self-signed cert. So I assume it is working.
But when I click on
"Administration"
“User Management”
“Active Directory Permissions”
. It still showing the message below.
Because SSL is not enabled, Active Directory user credentials will be sent to Web Reports in the clear. Learn how to enable SSL.
I am not sure what happen and is SSL working or not…
When you enable SSL check the value of HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\BigFix\EnterpriseClient\Settings\Client_WebReports_HTTPServer_PortNumber on your server as this will indicate which port needs to be used in the web address. I may be wrong but i have a sneaky suspision this automatically changed to 443 when i did it on our infrastructure.
If you havent already have a look at this site which helps you through the process of enabling SSL for Web Reports:
I shoould mention just in case that the registry path is for a 64 bit machine if you are using a 32 bit one it will be
HKLM\Software\BigFix\EnterpriseClient\Settings\Client_WebReports_HTTPServer_PortNumber
Just to confirm when you changed the port in the regisrty to 443 using the above key. Did you use the address https://server-name
or https://server-name
:443
