SQL Error in Webreports Console
Hi - When logging into web reports I am getting a SQL error which is replicated in the console:
At 18/06/2015 09:05:58
in site MaaS360 Mobile Device Management
in domain specification MDM-MobileDeviceManagementMaas360.BESDomain
in merging domain MDMD
different web reports descriptions
Any ideas?
Hi Andy,
The error does not cause any functional impact, and you should be able to clear it so it won’t appear anymore until you restart WR or the console. We will publish a fix shortly.
Thanks - the only issue is that all my scheduled reports are put on hold until I remember to go in and clear the error…
The fix was published earlier today, so you should no longer see this error.
