Software distribution problem
(imported topic written by awaissheikh)
Dear All,
I am new to Tivoli TEM, currently I am trying to install applications (such as VLC, Winrar) using its Software distribution task wizard. The task was created successfully. When I run the task on clients (Xp, WIn7) it does not respond/execute properly & the status on TEM console stays as “not reported”. Meanwhile when I look at the client services I found the same setup running, and it continues running without any result. I used the same task wizard for another installation (adobe reader) it all went well & the installation succeded. Please let me know if I am doing anything wrong & anything else from logs, relevance or action script is needed for clarification.
Regards,
Awais
(imported comment written by awaissheikh)
Okey…Just to update this thread, got the problem resolved by running tasks silently. I traced it using fixlet debugger.
Thanks.
(imported comment written by MBARTOSH)
You should use the Dashboard “Manage Software Distribution Packages” for your custom packages.
