SOAP API Using SSL
(imported topic written by Bhushan Chirmade)
Hello,
Would like to know if SOAP API can be configured using SSL? Any documentation link?
Regards,
Bhushan
If you enable your web reports for HTTPS, the SOAP API will also communicate over HTTPS…
Check out the web reports guide here: http://publib.boulder.ibm.com/infocenter/tivihelp/v26r1/index.jsp?topic=%2Fcom.ibm.tem.doc_8.2%2Fwelcome%2Fwelcome.html
