When you run a manual Windows Update, you have to select the option to search for other Microsoft software also. If you don’t do this, you’ll only get a minimal set of updates. Fortunately in Windows 10, the manual Windows Update is more closed and grabs everything relevant. This can be good and bad. When you run a manual Windows Update, you have to select the option to search for other Microsoft software also. If you don’t do this, you’ll only get a minimal set of updates. Fortunately in Windows 10, the manual Windows Update is more closed and grabs everything relevant. This can be good and bad.
I’ve found Bigfix to be easier to use that SCCM - and just as powerful. Don’t give up on BigFix, it’s a great product that has the muscle of IBM behind it.
