Simple Relevance Question - Model Number = "String"
I want to run a simple relevance statement to say if a mode number equals a specific model, make it relevant…What am I doing wrong, I keep getting “False” below are two examples…
Example 1:
q: if (exists wmi) then (string value of select “Model from Win32_ComputerSystem” of wmi) else (“N/A”)
A: PowerEdge 2650
q: (if (exists wmi) then (string value of select “Model from Win32_ComputerSystem” of wmi) else (“N/A”)) = “PowerEdge 2650”
A: False
Example 2:
q: string value of select “Model from Win32_ComputerSystem” of wmi as string
A: PowerEdge 2650
q: string value of select “Model from Win32_ComputerSystem” of wmi as string = “PowerEdge 2650”
A: False
Hey mboseck,
I think if you look at your result, you will see that it has a number of trailing spaces (some WMI queries for hardware return extraneous spaces)…
Try this:
q: string value of select “Model from Win32_ComputerSystem” of wmi as string as trimmed string = “PowerEdge 2650”
Awesome Ben, that was it, and the as trimmed string worked!!! Thanks for the quick response
