Hello everyone,
I’m working on a use case in BigFix and would appreciate your recommendations and best practices.
I have developed a Task that deploys and executes a PowerShell script on endpoints. The script scans local drives for potential credential patterns (e.g., “password”, “pwd”, “clave”, etc.) within files such as .txt, .log, .ini, and .config.
The script works as expected and generates a CSV file locally with the findings. However, the output may contain sensitive information, which raises a concern about how to securely collect and centralize these results.
Current situation
The scan runs locally on each endpoint via BigFix Agent
Results are written to a CSV file on the endpoint
The data may include sensitive content
No data exfiltration method has been implemented yet
Main question
What would be the recommended approach to securely transport or centralize these results using BigFix capabilities?
Options I'm considering
Uploading the file via BigFix Upload Manager
Sending results through Analysis / Properties (seems limited for large/sensitive data)
Writing to a secured network share
Using encryption before transfer (e.g., encrypting CSV before upload)
Key concerns
Protecting sensitive data during transit
Avoiding exposure on endpoints
Ensuring secure storage/access control on the server side
Keeping the solution scalable and maintainable
If anyone has implemented a similar use case or can suggest best practices (or things to avoid), I’d really appreciate your input.
Thanks in advance!
