Hello,
I would like to run this command
Disable-NetAdapter -name “Wi-Fi” -Confirm:$false
What is the best way to deploy this on my clients?
TIA!
Hello,
TIA!
In very basic format you could use
waithidden powershell.exe Disable-NetAdapter -name "Wi-Fi" -Confirm:$false
If you wanted to be a bit more advanced with it you could use
continueif {exit code of action = 0}
Or if you really wanted and you are using BigFix 10.0.4 - you an just change the script type to PowerShell and use native powershell scripting
