Roles and sites question
(imported topic written by beasleya)
Which scenario would be more efficient…
  1. Granting read permissions globally on external sites
or
  1. Adding external sites to a role and assigning the role to all operators
or does it make no difference
It depends on the level of control you’d like to have over permissions.
Granting permissions globally means if at a later date you want to change that, you’ll have alot of cleanup work to implement individual permissions to users/groups.
on the other hand, if you specify permissions based on roles, you can easily add/remove users from various roles as they move from position to position. The work here is clear, everytime you have an operator change positions a little prep-work will be required for them to have access to the proper content for their new position.
(imported comment written by beasleya)
I was thinking more in terms of what is internally more efficient. E.g. propogation of actionsite, etc…
Which scenario would result in better TEM performance ? (maybe it makes no difference ?)
Ad far as I’m aware there is no difference. I’m not 100% on the new 8.2 roles feature but considering every user that logs in gets their own operator site, I’d assume the impact on the infrastructure would be identical.
I believe when users log into the console, their new “abilities” or removed abilities will propagate at that time.
Ok thanks, sounds like its not much of an issue either way.
