RHEL 4 <not reported> in Console
(imported topic written by linuxishawt91)
I have a machine running the RHEL 4 BES Agent and in the console I can see the “Computer Name” but all the other retrieved properties are set to “”. I’m running 7.0.2.103 so efficient MIME isn’t the issue and I verified that the client can get UDP messages.
The log files give the following clue
" At 09:15:00 -0700 - actionsite (http://bigfix:52311/cgi-bin/bfgather.exe/actionsite)
FAILED to Synchronize - BigFix could not verify the authenticity of the site content."
I have reinstalled the client since I went from eval to production and the process I used is the following.
rpm -ef BESAgent-7.0.2.103-1
rm -rf /var/opt/BESClient
rpm -ivh BESAgent-7.0.2.103.i386_rhe4.rpm
wget http://bigfix:52311/masthead/masthead.afxm
mv masthead.afxm /var/opt/BESClient/actionsite.afxm
/etc/init.d/BESClient-7.0.2.103 start
Anything I’m missing?
KV
(imported comment written by sthull)
You need to remove the old masthead and place the new masthead in /etc/opt/BESClient, not /var/opt/BESClient.
See http://support.bigfix.com/install/besclients-nonwindows.html#rh32
Regards,
Steve
(imported comment written by linuxishawt91)
You’re the man. Worked like a charm.
KV
