I removed an analysis by accident this evening. Is there any possibility that it can be un-removed?
Hi there,
The BigFix database has stored procedures to un-delete some content, but not sure if there’s one for Analysis - I will check and come back to you.
could only find a stored procedure for actions, but having though about it you may be able to find the analysis from old actionsite versions on the server - have you looked there yet?
Find the site ID where your analysis was and look for the various versions of that site:
“C:\Program Files (x86)\BigFix Enterprise\BES Server\wwwrootbes\bfmirror\bfsites”
I was able to find the .fxf and am rebuilding the analysis from there. That’s easy enough. Thank you
