REST: Sending parameters to baselines are not used in underlying components
(imported topic written by JesperLarsen)
When the TEM managementconsole is taking an action having the source being a Basline and the target being a computer , the UI prompts about parameter values for the underlying components.
I tried to do the same thing with the REST api: Creating a SourcedFixlet (pointing at a Baseline), providing parameters as required by the underlying components( see the BES-XML below). But it seems as the parameters are never used.
So how am i suppoed to send the parameters via the baseline to the underlying components?
Kind regards Jesper
From wiki:
<?xml version="1.0" encoding="UTF-8"?>
   <BES xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BES.xsd">
   <SourcedFixletAction>
   <SourceFixlet>
   <Sitename>TestSite</Sitename>
   <TaskID>83</TaskID>
   <Action>Action1</Action>
   </SourceFixlet>
   <Target>
   <ComputerName>bhobbs-db</ComputerName>
   </Target>
   <Parameter Name="testparameter">testvalue</Parameter>
   </SourcedFixletAction>
   </BES>
