Reporting on Components of Baselines
Is there a way to get a report of components (tasks/fixlets) and which baselines they are included in?
You can do it the other way up - get a report of all baselines and the fixlets/tasks they contain
( name of it , name of site of it , names of components of component groups of it ) of bes fixlets whose ( baseline flag of it )
I apologize up from for my lack of knowledge but I don’t know where to run this. Is this in Web Reports as a custom report?
The code above is session relevance. If you’re interested in learning more, you can read about it here: http://support.bigfix.com/fixlet/documents/Session%20Inspectors%2081_110719.pdf
There may be a newer version of that guide somewhere.
Long story short, in the console, you can press Ctrl+Alt+Shift+D and check the “Show Debug Menu” box. Now you’ll have a Debug tab in the menu bar, and you can open the Presentation Debugger. You can run session relevance from there, and see results within the Presentation Debugger window.
