Repair BESClient using setup.exe
(imported topic written by SLB)
As there are known issues in InstallShield 11 creasted MSI’s for Vista 64 (http://forum.bigfix.com/viewtopic.php?id=3276), I was wondering if anyone can provide command line switches that can be used with setup.exe to silently install/re-install an existing BES client installation.
Based on obvious options, setup.exe /s /r seems to do the trick but I was hoping to get confirmation that this the correct approach. The preference is to avoid creating a process that has to detect if BES is currenlty installed, perofrm an uninstall then do a new install.
TIA
Rob
Hey Rob,
Those options seem correct, and I believe the agent will reinstall itself when run silently… So it looks like you are on the right track…
Here is some more info about the agent installer command line options:
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=222
