The relevance was modified for KB4561600 and now over 600 of my servers report that its needed, however it is not. Only about 30 require this update. If its pushed to a server that doesn’t have it installed, it fails, as one would expect.
Also seeing similar behavior. Also confirmed that the servers in question do not need the update -again with the exception of a few.
I have opened a case with HCL I found that they were missing the relevance statement below, I had to create a custom copy to get this package deployed
if (exists key "ApplicabilityEvaluationCache\Package_for_KB4561600~31bf3856ad364e35~amd64~~10.0.1.0" of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing" of native registry) then ((set of (7;112) contains item 0 of it AND set of (4294967264;4294967232;0;2;4;32;64;101) contains item 1 of it) of (value "ApplicabilityState" of it as string as integer, value "CurrentState" of it as string as integer) of key "ApplicabilityEvaluationCache\Package_for_KB4561600~31bf3856ad364e35~amd64~~10.0.1.0" of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing" of native registry) else ((exists keys ("Microsoft-Windows-CoreCountrySpecificEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreSingleLanguageEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EducationEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EducationNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseNEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSNEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-PPIProEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ProfessionalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ProfessionalNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerDatacenterEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerDatacenterEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerSolutionEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerStandardEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerStandardEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0") whose ((it = 6 OR it = 7 OR it = 96 OR it = 112) of (value "CurrentState" of it as integer)) of item 0 of it AND (exists keys ("Adobe-Flash-For-Windows-Package~31bf3856ad364e35~amd64~~10.0.14393.0") whose ((it = 6 OR it = 7 OR it = 96 OR it = 112) of (value "CurrentState" of it as integer)) of it AND exists keys ("Microsoft-Windows-CoreCountrySpecificEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-CoreSingleLanguageEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EducationEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EducationNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseNEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-EnterpriseSNEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-PPIProEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ProfessionalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ProfessionalNEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerDatacenterEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerDatacenterEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerSolutionEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerStandardEdition~31bf3856ad364e35~amd64~~10.0.14393.0";"Microsoft-Windows-ServerStandardEvalEdition~31bf3856ad364e35~amd64~~10.0.14393.0") whose ((it = 6 OR it = 7 OR it = 96 OR it = 112) of (value "CurrentState" of it as integer)) of it) of item 0 of it AND (exists key "amd64_adobe-flash-for-windows_31bf3856ad364e35_none_b4179b8118d18c9f" whose (exists key (if (exists default value of it) then default value of it as string else "10.0") whose ((it >= "10.0.14393.0" AND it < "10.0.14393.2922") of (default value of it as string as version)) of it) of it OR exists key "wow64_adobe-flash-for-windows_31bf3856ad364e35_none_be6c45d34d324e9a" whose (exists key (if (exists default value of it) then default value of it as string else "10.0") whose ((it >= "10.0.14393.0" AND it < "10.0.14393.2922") of (default value of it as string as version)) of it) of it) of item 1 of it) of (key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages" of it, key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners" of it) of native registry)
Thanks for the update. I edited your post slightly to add code tags.
This is resolved in site version 3564
