We’re having project to convert Active Directory GPO into BigFix Actions/Fixlets. In our environment we do have multiple languages configured.
Need some help with below relevance and see if this is possible
Command I run is following
auditpol.exe /set /subcategory:“Computer Account Management” /success:enable /failure:disable
Same command but using “GUID”
auditpol.exe /set /subcategory:“{0CCE9236-69AE-11D9-BED3-505054503030}” /success:enable /failure:disable
For relevance the following is used
I’ve only copied most important part of this
concatenation “|” of (if it then “ENABLED” else “DISABLED”) of (audit failure of it; audit success of it) of system policies of subcategories whose(name of it as lowercase = “Computer Account Management” as lowercase) of categories of audit policies
How would I be able to use GUID in the relevance to replace “Computer Account Management” with GUID
Thx for help
Nevermind found the answer
Updated relevance using GUID
((version of client >= “9.2.5.0”)and name of operating system as lowercase starts with “win10”) AND (not exists 1 whose(conjunction of((item 0 of item 0 of it = “IGNORED” or item 0 of item 0 of it = item 0 of item 1 of it)and(item 1 of item 0 of it = “IGNORED” or item 1 of item 0 of it = item 1 of item 1 of it))of((preceding text of it, following text of it)of first “|” of(“ENABLED|ENABLED”),(preceding text of it, following text of it)of first “|” of concatenation “|” of(if it then “ENABLED” else “DISABLED”)of(audit success of it; audit failure of it)of system policies of subcategories whose(guid of it = “{0CCE9236-69AE-11D9-BED3-505054503030}”)of categories of audit policies)))
Are you just trying to make sure that it’s relevant when the success auditing is enabled and the failure auditing is disabled?
Something like this would be a lot more concise I think:
(not it) of (audit success of it and not audit failure of it) of system policies of subcategories whose (guid of it = "{0CCE9236-69AE-11D9-BED3-505054503030}") of categories of audit policies
Hi William,
Thx for the update this relevance is indeed a lot more easier to read, and quicker to process. I’ve taken the other relevance from the legacy fixlets they also do the trick but as you mentioned harder to read a bit more complex.
Thx and will update accordingly.
