I am getting the correct ouput as in analysis but can i change this to client relevance value to “true” or “false”
q:if (exists true whose(if true then exists device type else false ))then device type else(if (exists value of settings "_BESClient_DeviceTypeOverride" of client)then (value of setting "_BESClient_DeviceTypeOverride" of client)else(if(it starts with "Mac OS X")then(if(it contains "Server")then "Server" else (if(((exists key whose(it as string as lowercase contains "battery") of entries of dictionaries of nodes of it) OR (exists node "AppleACPIPlatformExpert/SMB0/AppleECSMBusController/AppleSmartBatteryManager" of service plane of iokit registry)of it)of service plane of iokit registry)then "Laptop" else "Desktop"))else(if (it starts with "Win")then (if (it as lowercase contains "mobile")then "Mobile" else(if (exists key "HKEY_LOCAL_MACHINE\HARDWARE\Description\System\BIOS" whose (value "SystemManufacturer" of it as string as lowercase contains "vmware") of registry)then "Server" else(if (nt workstation product type != product type of operating system)then "Server" else(if (exists active device whose (class of it as lowercase = "battery" AND service key value name of it as lowercase = "cmbatt" AND (description of it as lowercase contains "microsoft acpi" OR description of it as lowercase contains "acpi microsoft")))then "Laptop" else "Desktop"))))else(if (it contains "Linux" OR it contains "AIX" OR it contains "Sun" OR it contains "HP-UX" OR it contains "VMware") then ("Server") else(if((it contains "ios" OR it contains "android" OR it contains "ipad" OR it contains "iphone" OR it contains "ipod" OR it contains "smartphone" OR it contains "msft-" OR it contains "nokia" OR it contains "palm" OR it contains "pocketpc" OR it contains "htc")of(it as lowercase)) then "Mobile" else "Unknown")))))of name of operating system
You could take the result then compare against a set of values that meets your use case to get a boolean
Q: (if (exists true whose(if true then exists device type else false ))then device type else(if (exists value of settings "_BESClient_DeviceTypeOverride" of client)then (value of setting "_BESClient_DeviceTypeOverride" of client)else(if(it starts with "Mac OS X")then(if(it contains "Server")then "Server" else (if(((exists key whose(it as string as lowercase contains "battery") of entries of dictionaries of nodes of it) OR (exists node "AppleACPIPlatformExpert/SMB0/AppleECSMBusController/AppleSmartBatteryManager" of service plane of iokit registry)of it)of service plane of iokit registry)then "Laptop" else "Desktop"))else(if (it starts with "Win")then (if (it as lowercase contains "mobile")then "Mobile" else(if (exists key "HKEY_LOCAL_MACHINE\HARDWARE\Description\System\BIOS" whose (value "SystemManufacturer" of it as string as lowercase contains "vmware") of registry)then "Server" else(if (nt workstation product type != product type of operating system)then "Server" else(if (exists active device whose (class of it as lowercase = "battery" AND service key value name of it as lowercase = "cmbatt" AND (description of it as lowercase contains "microsoft acpi" OR description of it as lowercase contains "acpi microsoft")))then "Laptop" else "Desktop"))))else(if (it contains "Linux" OR it contains "AIX" OR it contains "Sun" OR it contains "HP-UX" OR it contains "VMware") then ("Server") else(if((it contains "ios" OR it contains "android" OR it contains "ipad" OR it contains "iphone" OR it contains "ipod" OR it contains "smartphone" OR it contains "msft-" OR it contains "nokia" OR it contains "palm" OR it contains "pocketpc" OR it contains "htc")of(it as lowercase)) then "Mobile" else "Unknown")))))of name of operating system) is contained by set of ("Desktop";"Server";"Something1";"Something2")
A: True
T: 0.457 ms
I: singular boolean
