I used the Windows Software Distribution Wizard to create a package for installing new 3rd party software. The package is failing on multiple clients. Using the Fixlet Debugger, I found it’s failing on this item:
wait “{pathname of system folder & “\msiexec.exe”}” /i “{(pathname of client folder of current site) & “__Download\BalsamiqMockups_Ver2221_R1.msi”}” /qn /norestart
with the error: Relevance clauses must be surrounded by { and } guards
The thing I don’t understand is that this line in the action script hasn’t been modified from what the Wizard created. So why is it failing?
I’m in the office now and just re-read your original Message.
You are using the “Software Distribution Wizard”.
According to IBM
the Windows Software Distribution Wizard is being deprecated.
Have you tried using the Software Distribution Dashboard? It creates a much more robust and flexible Task. It actually builds a .BAT file on the fly that installs the software and records any output to a Software Distribution Log on each target.
BTW: I get the same error messages when I copy your WAIT line into my Fixlet Debugger. I also get the same error when I try to generate a Fixlet using the Wizard with a different MSI file here. I suspect it’s something changed in how the newer clients handle the inline relevance. It could also be why they deprecated the Wizard in favor of the Dashboard.
