Hello All,
I am working to automate the Relay Installation using IEM CLI . Any help /Supported documents will be appreciated.
Thank You
Mayank
Hello All,
Thank You
Mayank
Yes, that is easy to do. I’d suggest using the stock fixlet for Relay installation as your starting point. Make a copy of it, then add your own relevance to target whatever you plan to install relays on.
You may also want to add customized relay settings such as cache size, affiliation advertisement, etc in the same custom fixlet.
We do this and include the custom relay fixlet in our automated build process for certain machine roles based on location. It works well.
