(imported topic written by ShigeT)
Hi all,
Please tell me about “Relay Affiliation”.
TEM version is 8.2.1175.
I have the following settings:
TEM Server : not affiliation group
TEM Relay1 : affiliation group ( name is “relaygroup”)
TEM Relay2 : affiliation group ( name is “relaygroup”)
TEM Relay3 : affiliation group ( name is “relaygroup”)
TEM Relay4 : affiliation group ( name is “relaygroup”)
TEM Client1 : seeklist is “relaygroup”
TEM Client2 : seeklist is “relaygroup”
I think TEM Client should select TEM Relay.
However, TEM Client selects TEM Server after selecting TEM Relay.
Fri, 01 Feb 2013 13:03:09 +0900 Client detected possible network connection event.
Fri, 01 Feb 2013 13:03:09 +0900 DebugMessage Beginning Relay Select
Fri, 01 Feb 2013 13:03:09 +0900 Relay Selection: Setting control server
Fri, 01 Feb 2013 13:03:09 +0900 Relay Selection: For agent only.
Fri, 01 Feb 2013 13:03:09 +0900 Relay Selection: Initializing automatic selection with affiliations relaygroup
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: Seeking ‘relaygroup’ affiliated relay.
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: host: relay1. priority:0 weight:100
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: host: relay2. priority:0 weight:100
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: host: relay3. priority:0 weight:100
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: host: relay4. priority:0 weight:100
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.101 at TTL 1
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.102 at TTL 1
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.103 at TTL 1
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.104 at TTL 1
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.101 at TTL 2
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.102 at TTL 2
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.103 at TTL 2
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.104 at TTL 2
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.101 at TTL 3
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.102 at TTL 3
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.103 at TTL 3
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.104 at TTL 3
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.101 at TTL 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.102 at TTL 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.103 at TTL 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.104 at TTL 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.101 at TTL 5
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.102 at TTL 5
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.103 at TTL 5
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.104 at TTL 5
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Received echo reply from 10.1.1.101 at distance 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Received echo reply from 10.1.1.102 at distance 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Received echo reply from 10.1.1.103 at distance 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Received echo reply from 10.1.1.104 at distance 4
Fri, 01 Feb 2013 13:03:11 +0900 VerboseMessage RelaySelectLog: Selecting 10.1.1.101:52311 at 0-4
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: Attempt to select relay1:52311
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: Attempting to register via with parent. http://relay1:52311/cgi-bin/bfenterprise/clientregister.exe
Fri, 01 Feb 2013 13:03:11 +0900 Relay Selection: Attempt to register with http://relay1:52311/cgi-bin/bfenterprise/clientregister.exe
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage RegisterOnce: Attempting to register with ‘http://relay1:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.2.1175.0&Body=13775178&SequenceNumber=615&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&MaxHops=4&Root=http://temserver%3A52311&AdapterInfo=10-0b-a9-c0-e7-f8_10.1.1.0%2F22_10.1.1.212_0&AdapterIpv6=10-0b-a9-c0-e7-f8^fe80%3A%3A81d3%3A2a77%3Aac90%3Ab71f%2F64_0’
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage RegisterOnce: None authentication used.
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage Unrestricted mode
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage Not in grace period
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage Configuring listener without wake-on-lan
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage Registered with url ‘http://relay1:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.2.1175.0&Body=13775178&SequenceNumber=615&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&MaxHops=4&Root=http://temserver%3A52311&AdapterInfo=10-0b-a9-c0-e7-f8_10.1.1.0%2F22_10.1.1.212_0&AdapterIpv6=10-0b-a9-c0-e7-f8^fe80%3A%3A81d3%3A2a77%3Aac90%3Ab71f%2F64_0’
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage Registration Server version 8.2.1175.0 , Relay version 8.2.1175.0
Fri, 01 Feb 2013 13:03:13 +0900 Relay Selection: Setting control server relay1:52311
Fri, 01 Feb 2013 13:03:13 +0900 Relay Selection: Selection Complete
Fri, 01 Feb 2013 13:03:13 +0900 Relay Selection: Finished (selected nearby relay).
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage EvaluationManager::SetProcessingAction (on)
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage ShutdownListener
Fri, 01 Feb 2013 13:03:13 +0900 DebugMessage SetupListener success: IPV4/6
Fri, 01 Feb 2013 15:41:51 +0900 Client detected possible network connection event.
Fri, 01 Feb 2013 15:41:51 +0900 DebugMessage Beginning Relay Select
Fri, 01 Feb 2013 15:41:51 +0900 Relay Selection: Setting control server
Fri, 01 Feb 2013 15:41:51 +0900 Relay Selection: For agent only.
Fri, 01 Feb 2013 15:41:51 +0900 Relay Selection: Initializing automatic selection with affiliations relaygroup
Fri, 01 Feb 2013 15:41:52 +0900 Relay Selection: Going direct.
Fri, 01 Feb 2013 15:41:52 +0900 Relay Selection: Attempting to register via with parent. http://temserver:52311/cgi-bin/bfenterprise/clientregister.exe
Fri, 01 Feb 2013 15:41:52 +0900 Relay Selection: Attempt to register with http://temserver:52311/cgi-bin/bfenterprise/clientregister.exe
Fri, 01 Feb 2013 15:41:53 +0900 DebugMessage RegisterOnce: Attempting to register with 'http://temserver:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.2.1175.0&Body=13775178&SequenceNumber=616&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&Root=http://temserver%3a52311&AdapterInfo=10-0b-a9-c0-e7-f8_10.1.1.0%2f22_10.1.1.212_0&AdapterIpv6=10-0b-a9-c0-e7-f8%5efe80%3a%3a81d3%3a2a77%3aac90%3ab71f%2f64_0'
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage RegisterOnce: None authentication used.
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage Unrestricted mode
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage Not in grace period
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage Configuring listener without wake-on-lan
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage Registered with url 'http://temserver:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.2.1175.0&Body=13775178&SequenceNumber=616&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&Root=http://temserver%3a52311&AdapterInfo=10-0b-a9-c0-e7-f8_10.1.1.0%2f22_10.1.1.212_0&AdapterIpv6=10-0b-a9-c0-e7-f8%5efe80%3a%3a81d3%3a2a77%3aac90%3ab71f%2f64_0'
Fri, 01 Feb 2013 15:41:54 +0900 DebugMessage Registration Server version 8.2.1175.0 , Relay version 8.2.1175.0
Fri, 01 Feb 2013 15:41:54 +0900 Relay Selection: Setting control server temserver:52311
Fri, 01 Feb 2013 15:41:54 +0900 Relay Selection: Selection Complete
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.1 at TTL 1
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.1 at TTL 2
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.1 at TTL 3
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.1 at TTL 4
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Pinging 10.1.1.1 at TTL 5
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Received echo reply from 10.1.1.1 at distance 4
Fri, 01 Feb 2013 15:41:55 +0900 VerboseMessage RelaySelectLog: Selecting 10.1.1.1:52311 at 0-4
Fri, 01 Feb 2013 15:41:55 +0900 Relay Selection: Finished (selected root).
Fri, 01 Feb 2013 15:41:55 +0900 DebugMessage EvaluationManager::SetProcessingAction (on)
Fri, 01 Feb 2013 15:41:55 +0900 DebugMessage ShutdownListener
Fri, 01 Feb 2013 15:41:55 +0900 DebugMessage SetupListener success: IPV4/6
TEM Client selected TEM Relay(relay1) at 13:03.
But TEM Client selected TEM Server(temserver) at 15:41.
Can someone help me?
Thanks,
Shige
