Basically, I need a string value that has a name of “OPEN” and a value of "/R “C:\Program Files\Microsoft Office\OFFICE11\Library\Analysis\ANALYS32.XLL”
If you try the above regset with a value of “OPEN”=“I hate Excel”, it wil create it everytime, but there seems to be an issue with the slashes and quotes that is preventing BigFix from setting the HKCU key that I need set. I tried using an appendfile script as well and that didn’t help, or it’s more likely that I didn’t do it right. Using this regset has got me the closest to what I need to get to do. Please help!!!
Here’s what we’ve come up with to help resolve this issue, however I still need the parentheses around the “C:\Program Files\blah\blah\blah” in the registry. I’ve tried several different ways to get the parentheses, but it just isn’t working. Any and all help is certainly well appreciated!!!
regset “” “OPEN”="{escape of ("/R"&" " &""& “C:\Program Files\Microsoft Office\OFFICE11\Library\Analysis\ANALYS32.XLL”)}"
You need parenthesis around the path? or quotes? I will assume you mean quotes…
You can do it two ways:
Use an escaped quote in the registry (")
Use an escaped quote as part of your relevance (which is percent encoded: %22) and the “escapes of” will quote it automatically:
regset “” “OPEN”="/R “{escape of (”%22C:\Program Files\Microsoft Office\OFFICE11\Library\Analysis\ANALYS32.XLL%22")}"
Alternate option:
regset “” “OPEN”="/R “{escape of “C:\Program Files\Microsoft Office\OFFICE11\Library\Analysis\ANALYS32.XLL”}”"
In cases like these when you are trying to figure out registry syntax, it often helps to export the registry key using regedit and look at the export in a text editor.
