Registry problems
(imported topic written by sinucus)
I’m having some problems writing some relevance and I’m not sure what I’m doing wrong. I know I’ve read the proper why to handle this but I’m at a loss right now.
I need to check the registry to see if a 2 values exist and in a certain condition. If they don’t exist in that condition I want it to report as true. Here is what I have
if (not exists value “ActionCount” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Tivoli” of registry) then true else if ((exists value “Version” whose (it as string = “5”) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Tivoli” of registry) AND (value “ActionCount” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Tivoli” of registry as integer > 2)) then false else true
So what I’m looking for is to see if the entire hive exists, if it doesn’t, true.
If the Version is != 5, true
If the Version is = 5 AND ActionCount > 2 = false, else true. I.e. if it’s 1 or 2 true
I keep running into problems with one of the values doesn’t exist. I’m getting the “Singular expression refers to nonexistent object.” errors. Thanks
(imported comment written by MattPeterson)
If one of those values or keys do not exist then your statment will not work. You could add a couple | statements so if those statements error then try the next statement. Try this:
q:
if
not
exists
value
“ActionCount”
of
key
of
registry
true
then
true
else
if
exists
value
“Version”
whose
it
as
string
“5”
of
key
of
registry
false
AND
(value
“ActionCount”
of
key
of
registry
as
integer
2
false
then
false
else
true
A:
True
(imported comment written by sinucus)
thanks, I’ll give that a shot.
