I’m trying to create an analysis that will look to see if one of two keys exists then output the value of “DisplayVersion” for which ever one does exists.
the keys are:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator
or
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator
What I have so far is:
(exists key “HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator” of native registry) OR (exists key “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator” of native registry)
This get me a true/false
I can use this:
value “DisplayVersion” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator” of native registry as string
To pull the value of one or the other key.
What is need is to combine everything so that it looks for either key and gives me the value of whatever one it finds. If nothing is found then output “not installed”
Is this possible?
This is what I thought would work:
q: if (exists key “HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator” of native registry) OR if (exists key “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator” of native registry) then (value “DisplayVersion” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator”) of native registry as string OR (value “DisplayVersion” of key “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cisco IP Communicator”) of native registry as string else “”
E: This expression could not be parsed.
thanks,
Baraq
Console version 8.1.551.0 with DSS-SAM Version 1.3.1.597
