Hello, we have a couple of odd issues.
One is that the relays show sites they would gather that don’t exist, at least not in the console. How can you get rid of those? The are all linux, and the version we are on is 9.5.14
And two, we have nothing but 17NotASignedMessage in all of our relay logs. If anything else is there, it usually is a signal of problems. Can you make those odd errors go away?
I’d contact support. We had that problem when old deleted sites for some bizarre reason are still existent on endpoints (or if you have multiple environments that have different set of sites where you move machines from one to the other can contribute to it as well). We contacted support and they provided us from some scripts/fixlets to clean-up the references to the old sites off machines and then steps to make the relays clean up as well (had to remove some .xml files + bfsites off the Mirror directories if memory serves me right). It takes a while to clean things up but it can be done…
