Properties in analysis
(imported topic written by mcalvi91)
we have several analysis that contain the same property information (location by subnet, PC name, OS, etc). is it possible to share the property without having to create a new one for each analysis?
You can right-click on the column header and add global properties to the view for any Analysis…
sorry, should have clarified that this is for the analysis web reports.
MC
(imported comment written by tig91)
values of results of bes property
"MyCustomProperty"
Use the “Computer Properties” report to select arbitrary properties for your report…
On a similar note, if I’m creating a dynamic group, I guess there’s no way to use the value of some custom property as the trigger to join? Do I have to re-implement my property relevance in the group?
we tried that using the Computer Properties to add all the analysis’ properties but it only allows 4 properties. The analysis we are attempting to us has 13 properties in it.
Ah… Don’t pick anything for the “group by” sections… just multi-select in the “summarize” box… I don’t believe there is a limit on how many you pick.
It is quite a confusing report… I know… We have almost completely redone the web reports in the next version… I think everyone will like it a lot better…
Thanks,
