(imported topic written by Kirk_R)
Hello,
Trying to install Endpoint Manager on Red Hat Enterprise Linux 6.5. This is provisioned on Amazon EC2, using Red Hat Enterprise Linux 6.5 (PV) 64-bit AMI. Installing from the IEM-9.1.1082-Linux-DB2.tgz bundle. It’s looking like it installs DB2 correctly, but setup.sh eventually errors out with:
Info: Evaluation License successfully generated.
Info: Creating the Database for Server Component, please wait …
Error: An error occurred while creating the Database for Server Component.
Error: Unable to proceed with the installation of ‘IBM Endpoint Manager’. Refer to the installation log file ‘/var/log/BESInstall.log’ for additional details.
Contents of /var/log/BESInstall.log:
DB20000I The UPDATE DATABASE CONFIGURATION command completed successfully.
DB20000I The UPDATE CLI CONFIGURATION command completed successfully.
DB20000I The SQL command completed successfully.
Error: An error occurred while running the command ‘runBesAdmin -preinstall’
Exit Code= 1
Can’t see any obvious errors in system logs, server has plenty of disk, etc. Any help would be greatly appreciated. Thanks!
