system
October 16, 2012, 2:12am
1
I’m trying to write a fixlet to upgrade a software install on a Windows client.
The action consists of downloading two installers.
Installer1 actually uninstalls the original application.
Installer2 installs the newer version of the application. (I didn’t create the installers, I just have to deploy them)
Using the Fixlet Debugger, the two files download fine. (Download As with Continue IF commands)
What is failing is the EXTRACT command for Installer1, and I assume Installer2 would also fail.
I created the archive files using the BFArchive tool, and they consist of a folder with an MSI and external files for the MSI.
The command
EXTRACT __Download\Installer1.tmp
returns “runtime error : An unknown error occurred”
Anyone have any suggestions?
Installer1 is 28108656 bytes
Installer2 is 2203154856 bytes
system
October 16, 2012, 5:10am
2
I’ve been searching for a resolution to my problem, and found
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=450720
Can anyone confirm Nem0’s experience with the Extract command?
system
October 16, 2012, 6:01am
3
The extract does only work with BFArchive created files yes, so if you are using a generic ZIP or such, we will not understand it.
system
October 16, 2012, 8:26am
4
If it works with the BFarchive command-line tool, how can I identify the error I’m getting? The agent reports it as an unknown error.
system
5
system
October 16, 2012, 9:39pm
6
Have you tried extracting to a different directory? Have you looked at the archive to see if the pathnames are too long? Does the archive work on any machine at all? Can you extract the archive with the command line tool as well?
