Problem using { and } caracters in action script
(imported topic written by arnaud91)
I have a problem to create a task that should do the following :
delete __createfile   createfile until __End_of_File @echo off msiexec.exe /qn /uninstall
{405B593A-7D30-4649-980C-D01607995887
} /norestart __End_of_File   move __createfile uninstall.bat wait
"{pathname of client folder of site "BESSupport
" & "\RunQuiet.exe
"{pathname of client folder of current site}\uninstall.bat"
But if I try to deploy this task, the line beginning with “msiexec” and containing { and } characters reports as “failed”.
How can I use these characters in action script ?
Arnaud.
(imported comment written by dgibson91)
{} is used for relevance substitution
try replacing { with {"{"}
like this:
msiexec.exe /qn /uninstall {"{"}405B593A-7D30-4649-980C-D01607995887} /norestart
Even easier:
msiexec.exe /qn /uninstall {{405B593A-7D30-4649-980C-D01607995887} /norestart
(imported comment written by arnaud91)
Thanks for your quick answers.
I tried Jesse solution, it’s working great now.
(imported comment written by pcaprio91)
I have the following line in my action script (just 1 of 6 pieces of software to uninstall)
wait msiexec.exe /uninstall {{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn /norestart
The entire task completes successfully and uninstalls the other pieces of software and reboots the PC.
I log back in and find that this one piece of software did not uninstall.
I can manually uninstall the software from command line
msiexec.exe /X{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn /norestart
and even from Add/Remove Programs.
But when part of the custom task, it will not uninstall.
Any suggestions?
Those commands are slightly different… have you tried:
wait msiexec.exe /X{{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn /norestart
Hello Ben,
Yes I tried the /X and still didnt uninstall.
BigFix isn’t doing anything special except running the command so it might be an issue with the SYSTEM account… You might try running from the command line but using the SYSTEM account and see what kind of results you get:
http://forum.bigfix.com/viewtopic.php?id=1098
Ben,
I did the test you recommended, and it worked ok.
Just cant get the BES action script to remove the one app.
I am not sure what is going on because the application shouldn’t care who launched it (in fact it doesn’t even know)…
You might try this as a shot in the dark:
waithidden cmd.exe /C msiexec.exe /X{{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn /norestart
I tried both
and
waithidden cmd.exe /C msiexec.exe /uninstall {{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn /norestart
and this one application still does not get uninstalled.
I am close to out of ideas… Maybe try with RunAsCurrentUser and see if that works?
hello Ben,
I found during some testing with the msiexec command on the computer I am trying to uninstall the software on, if i use
MsiExec.exe /X{{B7B9409A-4496-4080-9F17-0557F347BCAF} /quiet
the software uninstalls fine.
if I use
MsiExec.exe /X{{B7B9409A-4496-4080-9F17-0557F347BCAF} /qn
nothing happens.
so I tried the following.
delete __appendfile
appendfile MsiExec.exe /X{{B7B9409A-4496-4080-9F17-0557F347BCAF} /quiet
move __appendfile delBSP.bat
extract RunAsCurrentUser-202exe.tmp
wait “{(pathname of client folder of current site) & “__Download\RunAsCurrentUser-2.0.exe”}” --w delBSP.bat
and also
delete __appendfile
wait “{(pathname of client folder of current site) & “__Download\RunAsCurrentUser-2.0.exe”}” --r delBSP.bat
I still cannot get BES to uninstall this one particular piece of software.
(imported comment written by ktm_200091)
pcaprio,
are you sure that the product code exists in hklm\software\classes\installer\products\Product Code?
If it doesn’t the app could have been installed only to the locally logged on user as opposed to ALLUSERS.
In this case you would need to do a command like msiexec /x “\servername\sharename\msiname.msi” /qn
