Hi
I need some help.
In Core protection Module => Web Reputation
In order to block Both (HTTP and HTTPS) websites in different browsers, i need to install trend micro plugin. that is “Trend Micro Osprey” it is working fine on my all browsers (google chrome , opera , Firefox , IE). but when I’ve updated all of these browsers.Now i am unable to block any HTTPS websites.
I don’t use this, Do you know how it is doing the blocking?
If it is installing an SSL proxy, then I wouldn’t recommend it.
You can use a proxy auto config file to blacklist domains and it works very well and doesn’t require any plugins or anything like that. It works just fine with SSL because it doesn’t actually proxy the connection, just check the domain against a list.
