Problem install tivoli endpoint manager client deploy
(imported topic written by v.sansone)
i try to install “tivoli ENdpoint Manager client deploy” in a system windows xp on virtual box, but the installation is always failure with error “logon failure”.
I try to connect at this system throught telnet, whit same credential, the connection has a success.
What can be the problem?
(imported comment written by Xie_Ran91)
This KB article has some useful information about the errors from the client deployment tool.
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=320
Check if it helps you。
(imported comment written by v.sansone)
Thanks , I solved it by following the directions.
